Coilgun Power
Microcontroller/Coilgun Ideas and Support
Main HomeMain Home  HomeHome  FAQFAQ  SearchSearch  MemberlistMemberlist  UsergroupsUsergroups  RegisterRegister  Log in
 juan caires
Go to page : Previous  1, 2
juan
PostSubject: ur5   Sun May 04, 2008 6:23 pm
Justin sr that kind of simulator I recommended you for this type of design .. thanks
PostSubject: Re: juan caires   Sun May 04, 2008 7:04 pm
I don't use simulators. I just try the code in the real thing.
Justin
View user profile http://coilgunpower.com
juan
PostSubject: r4   Mon May 05, 2008 3:22 am
Good afternoon sr Justin you use pwm (pulse width modulation) for the bucket, because I have a design with this method, I will buy you to the pic I was advised to aser the evidence and I need design is a 8x8 matrix .. .
PostSubject: Re: juan caires   Mon May 05, 2008 10:48 pm
Yes I use PWM. For a 8x8 2-D matrix wire it the same as a 4x4x4 cube and lay the 4 layers in a 2D space and not in a cube. That is the best way to wire it that I know of.
Justin
juan
PostSubject: urgente2   Fri Jul 04, 2008 12:57 am
goodnight sr justin, it would enable the program that will send me to use the cube 3x3x3 and the 4x4x4, to compare the program that I have not since I salts more than two colors .. thanks ..
PostSubject: Re: juan caires   Sun Jul 06, 2008 2:13 am
I don't quite understand what you would like. The code for the 3x3x3 and 4x4x4 cubes is available on the site. If you want help with you code post it!
Justin
juan caires
Page 2 of 2Go to page : Previous  1, 2
Coilgun Power :: PIC Microcontrollers :: LED Cubes-
